weaselbeak
XS650 Junkie
Darn funny that you ride an XS650 and the most common question you hear?....is that a Triumph? No, they are not the same, yes they look a lot alike, how close up be damned.
Yep, txxs, I've heard that yarn too; but it doesn't explain away the fact that the XS650 engine design has a strong resemblance to the Horex twin, and absolutely no resemblance to any Yamaha in-house 4-stroke design. I don't think Mama Yama wanted to admit that the baby's daddy was an early 50's German bike; retro just wasn't stylish right then.
All you need to do to see what I'm talking about is to put an XS650 motor beside a TX750 twin, XS360 twin, XS500 twin, SR/XT500 single, etc. on the bench and start taking them apart. You'll see many points of family resemblance in all but one of them. I don't know which design group at Yamaha did what, but engineers experienced in 4-stroke design would not have stuck 2-stroke style caged needle bearings in the small end of the connecting rods in the first run of XS1's! The 650 twin did not in any way reflect state of the art engineering when it was rolled out.
oh , I see that my post provokes controversy. I just wanted to know because I have one now XS650 1972 Suzuki LS650 1998 one and the possibilty to add xj650 and wanted to know the difference between xj and xs thank you for that I think I had my detailed answer.
First off, I'm not trying to "force" my opinion on you or anyone else, nor did I state that Yamaha was "blindly copying Horex;" of course Yamaha made their own contributions, and I doubt that the whole picture reduces to a matter of either/or. I'm not trying to be confrontational, but you asked about Horex connections and why I suspect that some of Yamaha's development stories are a bit exaggerated, so here are some major features of XS650 construction that are shared with the 500 Horex twin and are not shared by any of Yamaha's in-house designed motors.
1. Camshaft driven ignition (Yam ignitions are crank driven).
2. Sump plate on bottom of engine housing brass strainer, second brass strainer in right engine cover (Yam uses paper cartridge or spin-on filter).
3. Oil pump in right engine cover (Yam houses the oil pump in the crankcase).
4. Camshaft retained by rocker cover on ball bearings, rocker cover retained by head and cylinder fasteners (Yam secures the camshaft with plain bearing pillow box retainers with fasteners separate from those securing the head, rocker cover fasteners are separate from camshaft and head/cylinder fasteners).
5. Pressed on camshaft sprocket (Yam uses bolt-on sprockets).
6. Absence of crankshaft balancer.
None of these differences reflect post-1968 tech advances, but some would have required time to design and produce and increased production costs.
The TX750 is only one example. Many features are shared by all of Yamaha's known in-house designs that contrast sharply with the XS650 motor, but not with the Horex 500.
I've always noticed the uncanny resemblance to the Honda CB-350, and wondered if there may have been some corporate espionage going on over there...
I'm right and you're wrong.
Now that has been settled, let's have a beer. Who's buying?
