glennpm
Another Old Biker Nut!
Hi,
I'm building a kick start only'79 and am going to run an Acewell Speedometer-Tachometer. The unit has a clock and trip meter which I'd like to take advantage of, trouble is I'm going to use a capacitor and no battery.
I'm wondering if I could put in a small 12V battery like an A27 used for garage door openers. The ground of the battery and my ignition would be the same but I don't want to charge the battery, blow it up, when the PMA is running. Would a diode that allows current from the + battery work but prevent back flow from the PMA? If so what size would I need?
Thanks
Thanks
