Furious D
I have run into another brick wall in this project. After the fiasco I endured trying to get my rotor rewound I thought I was ready to ride but after putting everything together it still would not charge.
I ran thru the charging tests and found the stator is grounded to the case now. I have good readings wire to wire ( .5 Ohms) but all three show a .2 ohm path to the case.
Right now its on my workbench. Has anyone ever pulled a stator apart and sucessfully fixed it without having it rewound? I am at the point now that I dont wont to spend much more money repairing the less than adequate stock system and would like to upgrade to the Pamco system anyway . If I go that route it looks like I will have to upgrade the ignition as well since its an 81 with TCI.
