hi folks, I have my carbs (80 BS34's) off (again) and this time I did a couple of other things, but as I was cleaning in the float bowl area I noticed on the edge of the floats by where the pin goes through, next to the tang that gets bent up or down to adjust height, this portion is bent upward. PLease see attached pic.
I've looked at a couple of other photos of similar floats and don't see this anywhere. If nothing else this bent part prevents the float from travelling past a certain point.
Wondering if these are non-XS floats perhaps. Although I'd be really surprised, the carbs were super virginal.
I also drilled out the idle screw hole covers and checked the little o-ring, etc. Hope I set it right again when I put it back together.
Another thing that happened is I believe I lost a tiny ball from the enrichener rod. But maybe not. The one that is at the knob end, that sets those 3 holes (notches) is still there, I just thought I may have seen the other bounce and fly away into oblivion. Anyway, the rod works as it should and doesn't seem loose or anything, so I'm not going to stress over it.
But I was hoping someone could let me know if the part I circled in the pic looks like it is supposed to be that way - that one part bent upward.
thanks!
thanks!
