Oh; usually you can find an o-ring to fit, a little lube to ease the valve into the body helps you want a snug fit, but don't hammer it in.
on that, anything harder than the brass of the jet can damage itThe pilot jets have a VERY small hole through the end I typically use one strand of a stranded motorcycle copper wire to make sure it is clear. you should be able to look through it at a light and see a round hole. On the pilots and emulsion tubes clean the cross holes with soft copper wire.
We are with you here.
So tell us the whole gory story. We are looking for clues at the scene of the crime. to start: Are we 100% certain it's a carb issue? Could be ignition, poor grounds. water in the gas (insert long list).
