Sooo, there are no standard settings for aftermarket carburetors. Synch the lift and drop mechanically, then, counting turns to maintain synch, set the throttle stops to the lowest rpm the motor will hold, warm the motor, and back off throttle stops, again, to the lowest rpm the motor will hold. Then find the mix screw position that yields highest idle, back off the throttle stops to the lowest rpm the motor will hold, and continue this process until you have the mix screws and throttle stops at the setting that yields lowest steady rpm. Then richen the mix screws about 1/4 turn and turn the throttle stops to the setting that gives you an idle speed of about 1500 rpm and verify mix screw settings by killing one cylinder at a time, repeating the steps above; refer to the OE section of the Carb Guide. Set final idle speed to 1200 rpm.
If you must open the mix screws past about 2-1/2 turns to achieve this, go down one step on pilot jets. If you have to turn in as far as 1/2 turn, install a larger pilot jet. If jet needles must be moved, you may need to revisit the PJ selection; off-idle transitions will tell you if you need to raise the needles.
