Guys, if possible, when drilling an iron rotor, keeping the speed below about 430 RPM maximizes bit life, and reduces the risk of smoking the bit. At the proper speed and feed, any decent High Speed Steel bit will work. Drill pilot holes first, somewhere around 3/32 to 1/8 inch. Guides the bigger bit, and reduces heat build-up. My understanding is deburring or chamfering the holes causes them to retain debris in the holes, and can make gooves in the pads. If you drill part-way through each hole from each side, there will be almost no burr on the hole. That's how we drill acrylic on aircraft windows, to avoid big burrs, and a crater type blowout on the back side. Not much danger of that with an iron rotor, but it makes a nice clean hole edge on both sides, no deburr required!
