pa23driver
i finally got my dual output coil in from mikes today. so i fabbed up a mounting plate and wired up the coil into my ignition system. i wanted to run dual points on a single coil so i disconnected one condensor and hooked the points in parallel. i connected the blue wire (thicker of the two) to the points/condensor and black wire to my engine cutoff switch wire (red/white). i had a great spark going but the bike wouldn't start, just backfire so i decided to check my timing and it was amost to the "T" mark, which i thought was wierd considering it was dead on before i swapped coils. so i threw the batter tender on her and got to tinkering with the timing, next thing i knew i wasn't getting any power what so ever
is there a fuse somewhere that i'm not aware of that could've blown? is it possible i blew my coil already? if it helps i can post pictures.
any help is appreciated
