note the top and bottom tapered bearings are SETS do NOT mix the parts! The bearing with the larger ID is the bottom bearing. Once installed the new tapered races are very difficult to remove as the ID of the new tapered outer race is larger than the old race and you cannot get a drift on the "ledge" to remove it.
IMHO Best method to install;
Take an old race and weld it to a piece of pipe,
about 1 1/4" black iron pipe about 6" long so it's handy to hang on to while you hammer. other end has a heavy washer welded in as a striking face.
this both makes a good drift. and and the welding shrinks the race just enough that it will be a slip fit in the frame bore. Seating the new races takes some significant impact action, when the race fully seats, the "ringing" sound as you strike has a much lower, more muffled, tone.
I should make a longer mark 2A version of this drift with an inner race on the other end to seat the lower race down on the stem. Reuse the old seal on the lower stem. Remove the seal BEFORE attempting to remove the old race, it will stretch over the race, replace it after the new race is installed. There is a notch on the stem flange that it sits in.
