E advancer pma
Short answer is ....Yes........If the motor is 80 or later with an electronic ignition you will need to buy the advance rod and bushings for the cam. Mikes sells a full kit for these models
Original charging system has to have a battery to run the bike. Ignition system and charging systems are 2 completely different set ups.
To run battery less you will need a PMA Charging system
I have all my electronics (paughco ignition, capacitor, horn & horn button) inside a Brinks Security box....running "battery-less" with a PMA....I attached some pix. Hope it helps a bit? Good Luck....just remember to start the bike w/o the lights on!!!
