alwaysmonday
I have completed a simplified rewire of a 79 2FO and as I sit here looking at it I don't like the simple electrical connectors. They have to be the introduced weak link and potentially be a long term problem. For those of you who have done re-wires in the past... did you use bullet, spade, solder or weather pack (high dollar stuff) for your connections?
I have used spade connectors to plug into accesories (i.e. toggles/capacitor/pamco/flasher relay/signal stalks/Hughs reg/rec). All splices are soldered. Everything is covered in heat shrink for protection from the elements.
$0.01 for your thoughts.
Thanks
Thanks
