Don't run the engine if the battery voltage goes above 14.5 volts. Its bad for the battery and its bad for any light bulbs. Follow Skull's advice to use a fan, if running the engine for long periods.So I fired my project up again. I determined that the stator is producing voltage, so I am going to try the "retiredgentlemans" suggestion of piggyback a yellow onto one of the white wires from the stator. Now though, I noticed that the charging system is charging the battery at 13.5 volts, when the bike starts running, but it climbs continually and is at almost 16 volts after about 5 minutes. Anyone have any thoughts as to what is happening? I thought it should remain fairly steady? New battery installed this morning.
I don't mean to just do a visual check on grounds. Use a VOM on the lowest ohm scale, and measure the resistance from the black lead on the regulator to the battery negative terminal. It should measure less than 1 ohm, which may be just the the meter leads.I will turn on a large fan that I own next time. Yes it was at idle as the voltage started to climb, no light bulbs were connected, as it is just temporary wiring. I was still trying to determine if I could tag that missing yellow wire onto one of the whites from the stator, and just wanted to see if the rectifier and voltage regulator were all working. I am pretty sure that my grounds were all good.
I looked at the tech article on adjusting the regulator, and can check on that another day.
I have to say that the help and advice here on this site is priceless and so appreciated !!!
No, I can't help you with that. I bought mine using the internet. I havn't looked recently, but they used to be readily available on line.I did not do that, but I can.
Retired gentleman, you would not happen to know where in Canada, or Edmonton specifically, that I can buy one of these VR-115 regulators?
