What are you saying? They keep coming out of adjustment or they just start to clatter when run hard? I experimented with clearances when I first installed these. I was hoping that since they run quieter I could go with bigger clearances. Some claim bigger clearances work better and produce more power and performance. Well, I can't say I noticed any performance or power gains but I did find that you can get these adjusters to make noise like loosely set normal ones if you go too big. I ended up going back to nearly stock settings, .004" to .005" on the intakes and .006" to .007" on the exhausts. I wasn't too concerned about opening the exhausts more. I think the stock .006" setting is fine. I was happy to be able to increase the intakes a little though. I couldn't go over .003" with my stock screws or they clattered.
Now that you've mentioned it, I do notice a little more topend clatter after running hard. My best guess is the hard running knocks some of the oil out of the ball/cup joint where the foot attaches to the screw. Also, what oil weight are you using? If 40 wt., that will make more noise than the 50 wt. most of us run.
