A lot of you guys are missing the mark on vibration damping. It's not sheer mass that you should be after, but TUNED mass. Tom has it right, as do the bike manufacturers that put weights in only the end of the bar.
The goal is to provide a mass capable of vibrating at the same frequency as the bars, but in the opposite phase. Tom's idea is one of the better ones. The vinyl tubing does not fit tightly in the bars, and allows some movement. The lead shot adds mass. The tubing is then free to vibrate by itself, somewhat independent of the bars. If the mass is even close, it will tend to move with a delay, meaning; 1/the bar will push up on the tubing, 2/the tubing and shot will absorb that momentum, 3/the bar will reach its apex of movement and stop, 4/the tubing will use the absorbed momentum to begin moving up, 5/the bar will move down, and encounter the tubing and shot moving up against it. This cycle repeats. This is tuned mass damping.
Simply increasing the mass of the bars (solid steel stock, lead-cast inside bars, etc.) will not counteract the vibration of the bars. What it will do is move the resonant frequency of the bars outside of the range of vibrations present in engine. While it will help a good bit, its not as effective as a properly tuned mass damper.
Please don't take this as criticism of anyone's ideas or efforts. Just offering my limited insight.
oh, and the mass is most effective at the point in the bars that react the most, i.e., the ends of the bars. Mass near the center doesn't do much.
