jakobgoodnessgracious
All right, figured it was time to start a new thread.
I'm on the side of the street just down from my house because the old girl's engine died right now.
The Tx650a has died on me when I switch the lights on while idling a few times now. You can see when the engine isn't on if I switch the lights on the bulbs for the gauges get dim and then slowly rise to an average amount of power. The battery shouldn't be too low right now. The one thing I still have to fix is to get the corrosion off the starter cable but since I have a kickstart I haven't gotten to it yet. I did a search on the forums and I haven't seen anything exactly the same. I saw the points draw a decent amount of power and I know a lot of people like the panic systems. I need to double check my points are clean as well as I have not done that since I checked timing. Could either of these things be the problem (unclean points/unclean starter cable tips)? Where should I start?
