The 4 outside head studs allow oil to return to the block. The block (at the point where the head studs screw in) has oil drain channels cast in it. However, 2 of those channels are blocked off by the cylinder centering ferrules.
How can the oil get past these ferrules and back into the block? Are the 2 that's not blocked off be sufficient? Also, it seems that the 2 blocked stud holes would just fill with oil all the way to the head with no way to drain.
What am I missing here???
Thanks!
Thanks!
