bdholsin
XS Enthusiast
I've torn down my engine and I'm ready to order a bunch of parts, seals, etc. This will be my visual diary of the rebuild process.
I'm sticking with stock pistons and not going oversize as the current stock pistons are in good shape. I've cleaned the hell out of them and they are looking pretty good. Even got into the ring grooves and oil passages with pipe cleaners. There is absolutely no buildup or debris anywhere on them.
I've also made the decision tonight to get the case halves, cylinder block, head and head cover shot blasted to get rid of the awful paint that is half worn away. The thumbs below show their condition right now. I'll be spending some time in the pole barn with my scroll saw and band saw to make some covers to shield the surfaces that I DON'T want blasted.
Right now I know that I need new connecting rods, piston rings (I broke a couple of them), seals, cam chain, cam chain tensioner and guide.
1. The connecting rods (at the wrist pin) may be the source of my mysertious clatter when the engine is running. Maybe...I just don't know. I can clearly see that the copper coating is pretty much gone from my rod ends.
2. The original purpose of this teardown was to replace the cam chain, guide and tensioner. I was getting shavings in my oil so I figured this would be a good time of year to do it.
3. My goal is to have shiny aluminum on the outside when it is all said and done. I'm keeping my fingers crossed.
