eyewinder
Hello! I've been a member for several months, but this is my first post! Got my 1980 Special back in May and have been (very) slowly cleaning it up. The bike had been sitting for about 26 years, so there is a lot of work to do to get it running again (carbs are a work in progress). Learning a ton of stuff here – this site is an excellent resource!
My question pertains to the new euro bars I received from Mike's XS / XS650Direct. I think the centre of the bars is too narrow for my stock riser mounts, which are nearly 4-7/8" apart on the outside. The clamp position falls at the point where the bar starts to bend and is slightly oval (wider and flatter). Because of this, the bars don't seem to want to seat properly in the bottom clamp and the top one has a small gap where the bar is flattened. I'm concerned that it may be a safety issue. Has anyone else noticed this with the euro bars from Mike's?
I previously purchased a similar set of EMGO euro bars (with 4-1/2" center spec) and had the same problem. Prior to buying these ones I emailed Mike's and was told they have a 5" centre…
Thinking about sending them back. Appreciate any insight - Thanks
The bars are narrower at the bend:
The undistorted centre section is a bit less than 4", possibly less than the EMGO bars:
