Scallywag303
Need help... I have the false neutral happening in any gear, under load or shifting lightly, sometimes cant grab a gear at all. Checked the shift fork springs in right cover(not broken, properly adjusted star gear), all of the clutch rods and balls are in place, clutch properly adjusted, checked the neutral detent spring it looks fine and the detent is there. The shifter shaft moves left to right maybe a little less than 1/4". Any thoughts? motor is an 82 with an older 7 plate clutch swapped in by p.o..
Motor was just put into bike have no idea of previous history other then it runs fine minus the false neutral.
