Finished video.
Some of the mods:
VM carbs, PMA, spin on filter, oil cooler, single points, reed valve breather, catch can.
Fabricated: Tail light, headlight brackets, seatpan, side panels, battery carrier, catch can, air filters, engine mounts, chain guard, pipes mufflers, exhaust brackets and clamps, indicator brackets, speedo mount, centrestand, ignition swicth mount, oil cooler mount.
Machined parts: PMA mount, spin on filter base, chain adjusters, brake clevis, rod and adjusters, risers, speedo sensor mount, reed valve breather, pancake filters, fuel distributor, oil inlet plate, brake hose junction block, points cam and backing plate, coil mount, cable splitter.
And did I mention polishing? Geesus, I've done some polishing.
Most of this work I've detailed on this forum.
Don't know if I've shared this video of the finished product, but, here it is - again!.
Wonderful result and a credit to your build skills. It must give you great pleasure to look at, and pride of execution. I would love to own it, and ride it (which I know you can’t / won’t).
