smg65
I have found a lot of great info on the forum on how to remove the bezel to get at a loose speedometer faceplate. I have no problems with that job. What I specifically have not found, is how to remove the speedometer from the 1976 XS650C. I'm thinking there could be differences among the different XS models.
I'm pretty sure I'll find that it's a simple, straightfoward procedure... but I don't want to push and pull where I'm not supposed to and possibly damage the instrument or housing. Obviously, the acorn nuts need to be removed from the bottom of the speedo housing as well as the cable. Then, is it simply a matter of grabbing the speedo and muscling it up and out? I pulled a bit on it, but it didn't budge. I'd like to hear from those with experience before I yank hard and mess something up!
Oh... and please correct me if I'm wrong... it doesn't appear that the odometer reset knob would need to be removed as the housing is slotted so it could be pulled straight up and out.
Many thanks in advance!!!!
