SlowMaintenance
'76 XS650 Chopper
More pictures of the progress. Had a real pain in the ass of a time getting this seat to mount up correctly. If anyone has used the biltwell slimline seat you might have had similar issues. The bolts for the springs mount to the seat pan at about a 45 degree angle which makes hooking them into the bungs below nearly impossible. I had to bend the front of the seat pan to flatten the angle a little bit so that I could get them reasonably placed. All in all I think it came out decently, but I'd definitely go with a different seat or different springs if I had to do it again.
Left spring
Right spring (bolt is not pushed as far right as it could be, but even so, I think I may need to dremel out the adjustable seat pan notch to allow me to mount the bolt a quarter in further right.)
Slight torsion on the springs, but this was corrected a bit by bending the front of the seat pan down to reduce the angle. (Not bent in this photo)
Seat hinge welded on
Bottom view (hard to see I know)
Current state (minus the angle of those springs, I forgot to take pics after bending the seat pan)
From here I need to...
Mount the headlight
Install a sissy bar
Mount rear fender
Mount tail light and plate to sissy bar
Install engine
Wire headlight, taillight, PMA, Key switch, E-advancer and capacitor.
Get a new petcock w/ 90 degree bend to clear engine top mount
Kick it over and see what happens
Left spring
Mount the headlight
Install a sissy bar
Mount rear fender
Install engine
