Back to work on the racer but haven't got much done cause I'm waiting for parts: shocks, seat pad, cylinder head and exhaust parts. I don't want to start on foot peg mounts 'til the seat is done so I can get a proper feel on the ergonomics and I need to have the engine installed to set up the brake lever and right side foot peg cause this is a right side shifter so the brake pedal has to be in the right place. I also want to have the exhaust pipes in place when I set up the brake pedal and right peg.
Soooo, I got the head stay done at least. They didn't come out great but that's ok, they'll be hidden under the tank, no one will see
I had to make up another little transfer punch to locate the holes for the rocker box side of the stay. Also got the kick starter and tach drive plugs installed. I put a thin bead of silicon sealer on the plug before pushing them into place. They both have about a .001 to .002 inch interference fit.
Next is to order exhaust parts so I can start building that. After hearing some of the Yamaha twins racing at the track I realized I don't really need mufflers. Surprising how "not loud" these bikes are with straight pipes. So it'll be stainless low pipes exiting on the right with megaphones only.
Anyway, in the mean time I thought I'd try my hand at designing and fabricating a mini cherry picker/engine hoist specifically for this bike. How much does an XS650 engine weigh without carbs attached....125, 130lbs?? I can't lift and negotiate a lump that heavy into a frame
. So I'll need a tool to help me.
I made up some rough drawings and grabbed a pic from the internet to show what I have in mind. Pretty much a standard cherry picker design except mine will be MUCH smaller using the little bottle jack in the pic. I was thinking of using some 1.5" square tubing with .090 wall thickness for the frame. Think it will be strong enough? I would place the boom right below the intake ports at the base of the cylinder when lifting the engine. I'm thinking of holding the engine up with just tiedown straps so that I can jimmy it around if I need to when placing it in the frame. One strap around the cases and one strap around the top end to balance it. Feedback???? What does everyone think? Think it'll work? I think it would be a great challenge to make and design....only if it will works of course.
If I get to putting this thing together I'll post pics of my progress.
Also for those that know, is there a way to place these thumbnail pics I have here in the text body where I want? I tried the copy and paste thing but it didn't work. Thanks in advance for any help.
