trance
Hi, I'm working on rewelding my frame. I have a lincoln 180 amp AC buzzbox stick welder.
I know this isn't the best machine to weld a frame, but it's all I have right now.
I actually used to be a very good welder, with TIG and MIG, but have never been more than a passable stick welder.
Still, my current welds are horrid. I had to quit yesterday because they were so bad. Will have to grind several out and reweld.
Here's my problem: I had to turn the machine down to 60 amps to avoid burning through the tube. I'm running 6013 rod at 3/32". With this set up, I was getting lots of what I think are called "inclusions" in the weld - a gap in the weld bead that is full of slag. I cannot successfully weld over this gap, it just has a new gap in the same spot. I assume because the slag cannot escape through the new weld puddle w/o creating a new gap.
I think my problems are:
1) too low of an amperage for this rod. I was having better luck at 70 amps. Should I switch to 1/16" rod at 60 amps?
2) I'm probably not very steady with my weave pattern. Should I be weaving much at all? I had slightly better luck drawing little circles instead of a smily-face weave pattern. Instead should I be mostly dragging the rod straight w/very little weave?
Going to the store today for 1/16" rod and lots of grinding discs!
