andyxs
xs650 ***** browser
forks, gas tank, other misc parts
All parts are make offer, unless otherwise noted. I will ship everything USPS parcel post w/ tracking number unless you request some other method. Obviously for larger parts like the motors and frame I will have to make other arrangements.
This stuff is available locally as we'll just so you know.
1. Gas tank- I believe its from a 1981 special. Its indecent shape with one small dent and some surface rust inside. It will come with the petcock(moves by hand, but no guarantees) and the key.
2. Hardtailed frame- Sold
3. Motor- Sold
4.19 inch rim- comes with nipples, spokes, and the tire if you want all that. As you can see in the pictures, it is rusty.
5. handlebars- 7/8ths I believe and I have no Idea what they are from.
6. Kawasaki 650?? 4cyl motor- I was told all this needs is a stator to run, however that is not the case as the carbs are super gummed up. it does turn over freely though. I dont want to ship this either, but I will on your dime.
7. 16 inch rear wheel w/ drum- does not come with spacers and I'm not even positive if the drum is for this rim. the drum is seized where the arm spreads the shoes out.
8. stock seat- as seen on the stock frame
9.Motor mounts as seen on the stcok frame
10. Swing arm- I believe from an 81 special
11. brake stay- in swing arm pic
12. Triple trees- as seen on the hardtailed frame. I believe they are for 35mm forks.
13. 16 inch rim- has a lot of rust, comes with tire, nipples and spokes as you choose.
14. forks- SOLD
3. Motor- Sold
14. forks- SOLD
