Mine needs replacement. I would rather replace the plastic than the whole thing.
I've never found the plastic worn through, just falling off. What does get knocked off is that little plastic ridge down both sides but I'm not sure you need that.
I repaired one of my petcocks that was leaking several years ago using JB Weld. So far, it's holding.
is it only necessary to replace the front guide if the plastic is separating from the aluminum? mine is original with 17,000km and is intact but has some wear/hearline age cracking. same with the rear tesionern arm, does anyone ever replace these? also only due to separation of materials?
