Stoop22kid
Yet again this is my first build so I've never had this problem before.
Custom springer and custom axle with stock xs front spoke with speedo delete.
12 cm from inside to inside of springer
6 cm from inside to center of tire
1.5 cm from speedo delete to inside of springer on the left side (sitting on bike)
.4 cm from dust cover to inside of springer on the ride side (sitting on bike)
I ran a string from the center line of the front tire all the way back the frame to rear axle and everything SEEMS straight.
So if that's how you actually measure for what size spacers you need then I would need a 17mm ID, 20mm OD, 15mm wide spacer for the left side and a 17mm ID, 20mm OD, 4mm wide spacer for the right side?
Thanks in advance
Justin
Thanks in advance
Justin
