Fuse replacement ATC mini or standard blade sizing
weekendrider
Iron Horse cowboy
S.W. MO
Do you have a preference for the size if your replaced your OEM fuses?
Kinda shopping around.
If you buy the in-line fuse holders, the minis are easier to hide. That's what I do.
However, if you buy the larger blade fuses, you can get by without buying fuse holders at all. Female spade lugs will fit the blades perfectly. Use two, and you have your own in-line holder.
You can buy some pretty small fuse blocks for the minis if you shop around. If I have room, I'll go with the bigger ones, just because I can't see shit anymore within 18 inches of my face!
