pamcopete
Ride.Enjoy.Life is Simple
grepper,
Perfect!
Perfect!
Is this actually The Correct method? pushing back from the front (bike's front) under the gas cap directly on the piece that is connected to the cap's hook. I am not sure how you get in between the chromed cap top and this peice, tried every angle there is, and ground the tool to almost a knife edge to get in there.
I have tried for over an hour and got nowhere, I did manage to scratch the paint though. Has anyone drilled the hinge pin...AND sourced a replacement?
There are 2 types of Gas caps that look the same. 76-79 Standard and the 78-83 Special.
You need to identify what year/model XS650 you have for others to help define your problems...................even on a small thing like a Gas cap.
If you have no key, pushing the part of the sliding plate in that protrudes out the front of the lock assembly should release the latch for you .....
Now, many times this is easier said than done because the exposed portion of plate is tucked up into the cap. A stiff piece of sheet metal with a little 90° bend on the end might do it I think. I've done it with little screwdrivers but it can be a pain to get up in there. Try it on a cap you already have open and you'll see just what and how much you need to push.
Hi - are there any definitive pictures of a standard 1977 gas cap - open, showing how the latch (hook on cap) meets the stationary bar on the tank.
From what I can see looking under my cap it doesn't clearly look like the examples shown. But I can only see part of the hook and what looks like a cross piece (rusty metal) that would prevent tampering (as I am trying to do) that seems to block frontal access to the cap hook as it is engaged to the tank bar piece.
thxs.
I did grind the point off the very end of the pick which helped in finding and sliding the brass catch out of the way to remove the cylinders. Now, if there's a way to remove the ignitions cylinder........
