Airwolfie
XS650 Guru
I just replaced my shift shaft and lever. I though before closing the right, I'd have a look to see if the gear change works on the barrel. Well, It doesn't!
I can manage to shift three times and that's it, once down and twice up. I have tried spinning the back wheel whilst doing so, and no change. I then noticed under the star I only have four dowels, should there not be five?? It also seems like the arm does not or can't shift over far enough to push the star further. The distances of the little arm either side of the star are the same, so it's not that. I hope this fecking thing is not in the wrong way, because that means I will have to take the engine out and open up the bottom case!! I DO NOT want to do that!!! AAAAAAAAAAARGGGGGGHHHHHHH!!!! Never easy with this POS!!!
I'll try to take pics and do a vid maybe
