Another day in the shop, left to my own devices... First item was to bore out one side of the hub to accept a 52mm bearing:
The 19" conversion kit I have (Omar's) uses three 42x20x14mm bearings; one on the brake side, and two on the drive side. The stock rear hub uses a single 52x20x15mm bearing on the drive side. Widening the hub has spread my bearing base 5/8", so I'm going with a single bearing on the drive side, and in the stock size.
The cush drive has two basic elements: a drive flange that bolts to the hub and carries the cush elements, and a sprocket carrier that rides on the axle with a dedicated bearing, and engages the cush elements.
With the 52x20x15mm bearing in the hub, the drive flange is fit. In this shot, I've already drilled and counterbored for the M8 truss-head bolts that will hold the flange to the hub. The larger holes are for the six 1" polyurethane cush elements.
With the thirteen precision bores done (6 bolts, 6 cush elements, and 1 hubcentric bore), I can get onto the creative bit
For fun, style, and some weight reduction. There's still enough meat left for plenty of strength, but I think any more drilling and this piece will get impossible to clean! One more shot, bolted onto the hub:
Today I also took the other remaining 6"x6"x1" billet down to a faced 5" disc. That will will become the sprocket carrier, and will remain for another post!
