Johnt3
Still learning...
I like the shape of that tank osteoderm. What is this icing your talking about?
...for the pinholes, 120-grit sanding scratches, etc. This is a two-part, just a little smoother and harder-drying than the usual one-part finishing putty.
Beautiful work, as always.
Thanks! The machining is going okay, but just don't look too close at my paintwork
Nice. but hey! do you think the bolt threads will chew up the drive cushions? is it possible to thread just the head end of a bolt and leave the rest of it smooth at the same diameter as the outside of the threads?
You raise an excellent point, one that I was thinking about from the start. If you look closely, you can see that the portion of the threading that protrudes into the cush element has been turned down on the lathe for just this reason.
The final diameter of the de-threaded portion of each bolt is just a tiny bit larger than the minor diameter of the original threads, but smooth to the touch and a very nice fit into the polyurethane.
I thought of proceeding as you're suggesting, except that A) it's another fussy bit of machining, and the bolts are already very close to ideal, B) a non-threaded portion with a diameter equal to the major diameter of the male thread will not fit through the female-threaded hole.
From the start, I wanted to make sure that the major wear items were fairly standard and easy to remake/replace. In this case, I'm using a sprocket with a stock XS650 bolt pattern, off-the-shelf polyurethane tubing, and standard Grade 10.9 steel bolts (with minimal machining). I'm sure I haven't thought of everything, but I've been trying!
Is that a bright white? I was considering white for mine. It Looks good. Awesome hub!!
