Stock fronend Yes! Dropped tubes, how dropped? Here is another picture, they do not stick out in front as bad as they looked in the other picture. First set and can make them tighter.Gotta ask, those gonna clear a front end with a fender or dropped tubes at full compression?
They don't touch but are VERY close! p.s. I have not forgoten about your brace, making it before I leaveWould love to see a shot from the front. Are they "siamesed" together in front?
Crap, now I want some.
Thanks Hugh I tried to change them up some from your style, I keep on getting requests to make sets like that other set I made that looked like yours but came around the frame and down the sides, so far I only made that one set Take care Hugh. Scott p.s. Im going to give you a shout about your Banshee setup when I get back from vacationMy pipes are much tighter to the frame, but at 3.25" drop, with a 21" wheel and tire, they are nowhere near touching... Keep up the good work !!
Hi Guys, I can do anything you like, it would be the same cost as left side, prices on my site. Just remember that it's hard to take oil dipstick out because pipes are in the way and kickstart is there too! thats why I usually make them for left side. I make a 2into1 that allows you to remove dipstick for the right side if that interests you? I have done dyno runs with that pipe and makes good power at low RPM, not hi RPM like most. This run was with no rejet and stock cleaners, expect higher gains with proper changes.
Uploaded with ImageShack.us
