1. Dismiss Notice
    Dismiss Notice
Gracer is back - XS650 engine build without doner engine
Discussion in 'The Garage' started by gracer, Sep 11, 2019.
  1. gracer
    gracer XS650 Guy
    Guys,
    I'd like to build an XS650 engine that has a bunch of missing parts but I don't want to use a doner engine that could be rebuilt itself. I'm hoping to get some help here and let you know what parts I need in hopes that you may have it on a shelf somewhere and don't have to take it from a potential rebuild engine. If you catch my drift I think the effort will be worth while. I appreciate your help in advance. I'll be putting a list together soon. Gracer
    YamadudeXS650C, lakeview and Machine like this.
  2. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Hi Grace: there doesn’t seem to be a shortage of either complete engines or parts for XS650s from what I can tell.
    I know several people who have...several engines...;)
    JRay77, MrBultaco, Mailman and 3 others like this.
  3. gggGary
    Shipping's expensive, get up a wanted in your local craigslist or FB buy sell?
    Think my shelf has 20 motors....... In Wisconsin... spring trips to the southwest are common.
  4. gracer
    gracer XS650 Guy
    I decided to take your advice and found an xs650 engine on craigslist
  5. gggGary
    Great! Please post up pics n details,as you proceed!
    Mailman and lakeview like this.
  6. MrBultaco
    MrBultaco it ran before being parked Top Contributor
    666
    2,161
    243
    Colorado
    Gracer, your board tracker was one of the most beautiful XS650 builds I have seen. (calendar 2017):cheers:
  7. gracer
    gracer XS650 Guy
    I find myself in the same dilemma...but now with a donor engine that I do not want to take parts from but want to rebuild too. Oh boy!
  8. gracer
    gracer XS650 Guy
    Thanks for the kind words.
    gggGary likes this.
  9. MaxPete
    ...and THAT is how it starts.....
    gggGary and azman857 like this.
  10. gracer
    gracer XS650 Guy
    I'm making good progress on the engine build. I now have the bottom end all buttoned up. Gears are shifting, able to find neutral, kick start installed and works. Question: on the oil filter (in the side cover) how much should I tighten the plug that holds the spring and ball? I'm thinking make it flush with the tube it threads into?
  11. TwoManyXS1Bs
    Yessir, flush with the bolt's face...
    gracer and 59Tebo like this.
  12. gracer
    gracer XS650 Guy
    I got a bunch done on my engine build. I soda blasted the head and rocker box but it still shows some corrosion. I finished porting the head, lapped the valves, installed new valve seals, rocker box seals and rocker arms. I bought a complete head to do this and put those parts in the head I had with matching rocker box. Everything went together nicely! Cylinders are being bored this week.
  13. XSLeo
    Ebay has lots of engine parts. You can finish the rebuild of the second engine that way. Maybe build it a bit different than the one you have. I like the 750 kitted engine I my 75.
  14. gracer
    gracer XS650 Guy
    I'll consider that for sure. I see 700cc and 750cc discussion, is it just preference or is there a big difference in power/price?
  15. gggGary
    700 is about the limit on stock cylinder liners. To go 750 you'll need liners with a bigger OD.
    gracer likes this.
Share This Page
