Winner winner chicken dinner!!!Warshin’ and kickin’ with good results.
View attachment 236757View attachment 236758View attachment 236759View attachment 236760View attachment 236761
Jan I like that idea! I'm definitely planning on making a run at removing the dents somehow I just haven't made a plan. That innertube trick keeps popping up but maybe your thought is better.Thinking out loud
Dont know exactly how the petcock is installed But if it like on a 80
Perhaps that Tank dent can be tapped or pressed out from the Petcock hole
Helpful tip, use a heat gun to warm the paint before pushing the dent out. Heat will soften the paint and may prevent it from cracking. Not too much heat though.Jan I like that idea! I'm definitely planning on making a run at removing the dents somehow I just haven't made a plan. That innertube trick keeps popping up but maybe your thought is better.
Thanks for the tip, Terry. I've never messed with dents except to bondo (poorly) them away so this will be a foray into the unknown.Helpful tip, use a heat gun to warm the paint before pushing the dent out. Heat will soften the paint and may prevent it from cracking. Not too much heat though.
And while we're talking about it, I like to use 1/4" round steel stock, with the tip rounded or hardwood dowels. You can take a 2x2 piece of wood and drill a hole 1/2 way through it to use as a "handle" to help you push. Try to push slowly by hand. Hammers are a tool of last resort. Have someone watch the area you are trying to push out, that way you can see if you're in the right spot. Don't let perfect be the enemy of better.Thanks for the tip, Terry. I've never messed with dents except to bondo (poorly) them away so this will be a foray into the unknown.
PDR is the way to go.I had a young girl back into mine and knock it over resulting in this dent. Paintless guy was reasonable and did a really good job.View attachment 236777View attachment 236778View attachment 236779View attachment 236780
Trawlers?Color matched!
Jim, you are just negging me so I beg you to repaint it...the bike, not the boat.Dented and rusty?
Yes indeed. Visiting my wife’s folks in Gloucester, Massachusetts.Trawlers?
