I'm working on my re-wire, with stock switches, removing all the checkers, cancellers, etc...and just using a PMA, PAMCO, Signals, and Lights On/Off switch.
The stock 1978 Standard utilized a grounding harness. That is, instead of grounding on the frame or bolts, every signal, headlight, brake light, and most components have a black wire connecting them to the battery or switch grounds.
My question is this:
How do I effective ground components?
1) Switches. Do these have ground wires or does the bolt actually ground to the handlebar? In diagrams the horn button, brake switch, and it appear some of the other switches have black ground wires.
2) Signals. Can I ground these to the bolts used to fasten them to the frame? The headlight, signals, and brake light, as well as some indicator lights have a ground wire. I'm thinking of linking the rear signals and brake light to a ground at the battery, the indicators and headlight to a headlight mount, and the front signals to the frame. Will this be ok?
3) Components. The PMA 5-Wire Regulator requires a ground. Go to battery or someplace closer? The horn has a ground as well.
Where are places I can and can't ground to?
Posted via Mobile
Posted via Mobile
