Rexxis
Almost there...
I've been reading as much as I can abt matching a Harley hub to a stock XS 17mm axle and I can't find a definitive fix. If I have missed the answer to my question here, then please, someone point me in the right direction.
Let me start off by saying I'm running a Wargasser spool out front, not a Harley hub, But for the purpose of this thread that isn't important bc the ID of the bearing is the same as HD bearings, 3/4".
The OD of the bearing that came with the spool is 1 5/8". It seems, after several days of visiting and calling bearing suppliers, that nobody makes a bearing with a standard OD and a metric ID in the size I need(1 5/8 OD, 17mm ID).
So, therein lies the problem. I figured I would have a machine shop turn a sleeve for me that I can run between the axle and the bearing to fill the gap. 3/4" = 19.05mm. 19.05mm minus 17mm = 2.05mm. That means the sleeve will only be BARELY over 1mm thick. That sounds way too thin to be realistic to me.. or am I wrong here? Has anybody done this?
So now I'm thinkin' what if you get a bearing with the same OD but with a ID of 7/8?
7/8" = 22.249mm. 22.249mm - 17mm = 5.249mm
That would put the sleeve at 2.62mm thick which sounds a lil more doable.
EDIT**********
It seems you can't change one dimension of a bearing without the other one changing as well. The only ID for a bearing with a 1 5/8"OD is 3/4".
I know I'm not the only person who has ran into this problem so a definite answer would be awesome!
Thoughts or experience?
EDIT**********
