nick3757
XS650 New Member
Hi there everybody. I'm new here to the forum but not new to bikes. I'm in the process of buying an 81 XS650 and waiting for the title to come in. This bike is going to be my project now because my shovelhead softail project is just too damn expensive to finish now. I plan on building a wide tire XS so I have a couple questions.
1. I have a set of new 18x5.5 and 21x2.15 wire wheels and 180/55zr18 and 90-21 tires I was going to use on the softail. The back wheel is for a softail and the front is a wide glide I believe. The front hub width was around 6.75. The wheel bearing ID is 3/4" front and back and I Believe the XS axle is at 20mm. I would like to use a G&L hardtail on the bike.
Will the wide glide front wheel fit between the stock XS forks? And Would I just use an aftermarket Harley axle for the rear?
2. I was planning on running the Gary Poh offset kit also. Can someone recommend a 520 sprocket that will fit a Harley wheel?
Thanks in advance for the help.
