Zombis
So about 2 weeks I was cruising my 1980 XS, put about 150 miles on it for the first time since i bought it. I was pretty stoked on life and it was one of the first days that it stopped raining. pretty happy about it although it was ticking way louder than normal. When I mean louder than normal I mean it sounded louder than the exhaust, which was fairly unnerving. Got it home that night and reved the engine, not high just to like 4000 rpms in neutral reved it one more time and PING PING PING and then the engine died. tried to kick it over once and it sounded like a gurgle. effing $hit nuggets... pulled the spark plugs and turned the rotor over by hand once....
The intake valve on cylinder 2 was stuck wide open
Drained the oil, let it cool down over night and pulled the engine the following morning. After I pulled the tappet covers i found that the valve retainer exploded, dropped a valve, bent it all to hell; pulled the head valve gasket was toast, pulled the jug and noticed that the base gasket was torn in a couple spots. Piston didn't look bad just two small ding marks.
noticed something a little odd on the #2 jug above the the highest point along the head gasket area. There is a dent almost a chip in the cylinder sleeve. catches my fingernail and sits higher than any other spot on the jug/ head gasket surface.
I'm thinking it's going to need a new sleeve what do you guys think? or at least a used jug. I'll post some pictures later tonight and show all of you folks and see what you guys think.
stay tuned
stay tuned
