Ok Just stripped the engine down to the conrods I need to measure the tolerances to see if they are too worn these measuring tool needs to be bought
Then strip head down valves need to be measured another tool for that
bore dial for small holes and big holes vernier caliper engineering calipers
all cost money cheap one are shit expensive ones are on the money
thats why i asked you to factor tools in because they have to be bought by me to do the job of a re-build
Breaking the engine down was like opening a Pandoras box it reminded me of when i am working with a patient and I take them to there most painful place and they break down in tears
that was me dudes
It seems to me and this has no bearing on anyone else on this forum BUT by the time you buy all you need its cheaper to have the engine professional rebuilt by someone who knows there stuff specially if you want reliability and a tight functioning machine.
I paid £2400.00 for a very clean bike, yes it was about 400 over what i wanted it as all i saw before were PIGS, I was assured that the engine was ok and rebuilt 1000 miles ago this was not true and to be honest I did not believe them... no problem
I then went ahead and purchased all i needed to turn a bike that looks like a Harley into a cafe racer mission accomplished.
the cost of the that was a further £1200.00 give or take some change
Bike went well enjoyed it for a bit then boom ATU explodes changed that
Then oppps smoke left cylinder not to bad
could be electrics could be Carbs new high voltage coil iridium plugs Chuck in a Pamco kit lovley. runs well
still smoking valve stem oil seal changed new head gazket ...may as well ...
ported the intake lap in the valves
Opps did not skim the engine
still smoking .......
engine out again NOOOOOO leakage twomany and 5twins on the money
I did and do enjoy working on engines and bike and cars but
What my point is...
I will not do a better job than the professional engine builder, by the time you skim this hone that buy this and that even if your lucky and there are no mistakes the saving is minimal
I Have been quoted £1500 to £1800 for a full stock rebuild every part checked worn parts replaced engine bead blasted and cleaned bar side panels thats for me to polish so I get a new bike essentially.
If I take items to the engineering shop they will charge me for measuring and doing the work If you have to buy the stuff to measure the components its more expensive again that why you have to add the equipment you use tools to measure
Because i have not got them.
so if you have posted here
add up you measuring equipment and add it to your parts list and think of the hours you have spent to finish the job and times it by what you earn an hour and that what it cost you in total
from my perspective, I think it is great to do stuff yourself but without the right equipment it much more expensive your more likely to mess up and it will cost you more in the long run.
That is my point
In engineering and to measure the small tolerances you have to have to build a good engine you need accurate equipment and that cost around the price of a rebuild
The reason I started this Thread was because everyone assumed i had engineering equipment measure this and that
30 thou here 4 thou here
take it to the shop they will measure it for you
In England or more to the point where I live,, they charge you, sounds like in the USA its free... I was just reading a thread chap buy 553 pistons puts the on 447 conrods then wants to know why when he bought the timing mark to TDC he had 10mm of piston and rings hit him in the face and that,s not the only thread where stuff has gone wrong.
I really dont want that so Med Speed here I come and I knew you lot did not have the balls to say what it really cost you... case closed I win lololo
All the best Funky
P.S by the way JTrip72 that was funny because i look like that fella ... but with glasses lolol nice one
