I may possibly have to pull the head/ jug to put a new timing chain in, not sure yet. I have been breezing through some posts and what not, have found some info on copper gaskets but. Just curious what is the thinnest head gasket and base gasket I can get away with to slightly bump compression and not have to degree the cam back in or run into piston to valve issues? It would seem once I would get into PTV clearance the cam would def have to be degree'd back in, I do not really want to get involved in that. Or is it even worth the minimal gain in compression to worry about? I think I may also clean the intake ports up, match the carb spacers/ boots and ports up. Not polish but a blend, ruff. Looking for some insight.
