Ok so here is the deal I have a 1980 XS650 ("G" i think).
So recently in the past week i just got my bike back from the shop where I had my Stator, Reg/Rect and my Coil replaced along with a carb clean and gas tank clean. I got the bike back after a hefty bill and it ran perfect for two weeks. Last night all of a sudden after riding it to dinner i came out and started it but the headlamp did not turn on I flipped the high beam on it worked then flipped it off still no low beam then no high beam...so nothing! Also i never use my blinkers because they never work but i tried using them right before the bike was turned off. (could this have caused a short? maybe in the switch?) A year before this I had a problem with the headlamp and I bypassed the reserve lighting system and the the headlight worked fine until now. So now I'm stuck! Where do I look now? Connections? if not that then what? is there something else i can just bypass......I cant figure out why this headlamp is such a problem.
Please help and be specific!!
Thank you a lot in advance
