FreddieF
Hi all,
I've had my 84 Heritage Special for a couple of months and it had been running OK until last weekend when it suddenly started hesitating at highway speed during a long ride. Now it does it after a few minutes of riding. Low speed and idling don't show the problem.
The carbs have been out a few times and everything cleaned - everything is stock. Compression test is OK, cam chain adjusted, valve clearances are good, carbs are synced, no air leaks (unlit propane torch tested). Still no joy. The stuttering seems to get a bit better switching to PRI - but not much better - vacuum? Unrelated?
Last night I went for another test ride and noticed the headlight flickering a bit now and then - aha, inconsistent spark or something. Brushes are just at the point of replacement 7mm - would that cause the problems listed above??
And just how do you reinstall the brushes? Seems you have to turn the brackets upside down and have the wire go around it??? That's strange or I'm doing it wrong.
Thanks for the help!
