1. Dismiss Notice
    Dismiss Notice
Help! 36mm fork extension
Discussion in 'The Garage' started by jakeroper, Aug 20, 2019.
  1. jakeroper
    jakeroper XS650 Member
    hey guys, so I’m building myself a chopper and having issues finding a 36mm fork extension kit or even longer forks can anyone point me in the right direction
    Cheers!
  2. arcticXS
    arcticXS XS650 Guru Top Contributor
    36 mm diameter? XS came with 34 or 35 mm, depending on model year.
    Anyway, for a moderately extended fork, you could check out vintage MXers. Not a bolt on replacement, but most forks can be adapted to any bike.
  3. jakeroper
    Hi arcticXS, yes 36mm in diameter my bike year model is 75. I have done some research and have found 36mm tubes to be uncommon, I think generally they are on later models?
    Thanks for getting back to me
  4. 5twins
    20,059
    12,014
    813
    34mm tubes were stock on a '75 model. If you switch to 36mm tubes, you'll need different triple trees as well. You might check out some Viragos. They had long forks.
  5. jakeroper
    There are 36mm tubes on my bike, a previous owner must have swapped the front end out :(.
    Thanks for the info guys.
  6. MrBultaco
    MrBultaco it ran before being parked Top Contributor
    816
    2,597
    243
    Colorado
    To answer you question...depending on the forks you have, check out this site. He's been in business since the 60's
    franksforks.com
    arcticXS likes this.
Share This Page
