Hodakakid
Hodakakid
Hey Guys
I'm needing some advice/ideas on some troubleshooting. A buddy of mine (motorcycle mechanic) is working on my XS. Not long after I got the bike it stopped firing on the right cylinder. He deduced it wasn't carburetor or the coil and had little to no compression...so we tore into it looking at pistons and rings. We wound up replacing the rings (some of the rings were lined up in the gaps). Anyway the bad cylinder also needed one valve seat machined, which we had done at a local machine shop. We put it back together and it now tries to fire very sporadically but not enough to even heat up the exhaust pipe. Both cylinders have 120 psi. We have gas, fire, compression. What else do we need to look into?
Any advice would be appreciated.
