I drilled out the hole
Tapped with included tap and the put the helicoil in but it will only go so far in and it's stuck tight I mean as in it won't go in any further
I'm afraid if I try and back it out it will break off the tab at the end
Can i just pull it out or will a piece break of in there
Or dill it out or use the tap I'm at a srandstill here and I have locktite on the sob too
I also carefully ran the tap in there twice to make sure the threads were good
