Ravensmoor Bob
Hello Everyone!
Well I've trawled YouTube, read the Haynes manual, & of course looked on the forum for advise. Basically I have a UK spec XS2 9k miles from new, I've just re-commissioned her & can't seem to achieve the condition where you can engage gear & the clutch doesn't slip. When riding it feels as though the clutch is "dragging" but if I adjust the cable at the bars to reduce free play it slips! I have adjusted the screw in the casing as per the you tube clip someone suggested on here; cable fully slack, locknut released, centre screw just touching push rod, out 1/8 of a turn, lock, re-adjust cable to give 2mm free play at the bars.
Reading various articles the clutch is a relative weakness on the bike, & is a sod to adjust. Can someone please explain what I've done wrong or is it a strip down??
P.S. I am using Morris oil that I was told doesn't contain friction reduction additives & should be suitable for a 70's classic, but when I check the tin it seems to conform to too many specs to be a basic lubricant? perhaps this isn't helping?? Cheers Bob
