As Pete has mentioned several times on here it is a good practice to check the pma output before wiring in the pamco ignition. It's a 277 build pma pamco capacitor kick only, nothing but a kill switch and an led taillight and license plate light. No headlight hooked up at this point. So I finally got it to fire... Voltmeter hooked up and noticed immediately right about idle 17 or so volts dc. Had the digital meter set on the "20" setting vdc. So I shut it off right away. I didn't even bother to up the rpm and see where it went. Anyone have any idea what I can check for or try?
Thanks in advance
Thanks in advance
