scottpagesr
GTS
I wanted a rear spoke and disc brake for my street tracker. Flat track wheels are over $1K, so I modified a Honda CR rear wheel. Sprocket side was fairly easy, bought a solid sprocket (ebay) and machined out the center and drilled new holes. I used an RD400 front disc (ebay) which unbolts from it's hub. I made a new hub/adapter for the disc. Only issue was the bolts heads for the bolts used to attach the disc to the hub won't clear the disc mounting bracket unless a relief is made in the bracket. I also had to make new spacers. The CR wheel is common, fits multiple models for over a decade. I wanted stainless spokes so I bought from Buchanan. Note numer of spokes is 32, the front will be 36. Just a heads up did not matter to me.
