My unit is currently in for warranty repair/ replace. For good measure, I have replaced my coil with one that pete himself used for many years according to an old post.( its a Harley one 31609-80) I cleaned every electrical part with a red/white wire. What can i do to make sure my new unit will not go out again. I have now made sure the fuse in the ignition circuit (red/white wire) is a NEW 7.5 amp fuse. I plan on using good new electrical connectors to install it.
I’m using new plug caps and new plug wires as well as well as fresh spark plugs. My previous ground spot for the black wire off the pamco was where the old coil bolted on to the ignition.
Is that a good enough spot?
I am using the stock charging system and I replaced the brushes today. I cleaned the rectifier connections as well.
What else can I do to make sure it won’t happen again?
